Philco Superdyne 7
Hi Joe
A Philco with the inscription "SUPER HETERODYNE 7" on its escutcheon under the dial window would indicate either a model 70 (AC), or model 35 (battery).
How to tell them apart?
If the cabinet has three obvious screws with rosette flanges on the front panel which hold up the (heavy) PM speaker, then it is a 35. No visible screws in front indicate a 70.
Of course, looking in back will tell the tale for certain. No power transformer and tubes such as 30, 32, etc., indicate a model 35. That, plus a thick multi-conductor cable instead of an AC cord. Otherwise it is likely a 70.
Philco Superdyne 7 - by jamr005 - 06-13-2016, 10:28 PM
RE: Philco Superdyne 7 - by Steve Davis - 06-13-2016, 11:00 PM
RE: Philco Superdyne 7 - by morzh - 06-14-2016, 01:47 PM
RE: Philco Superdyne 7 - by Ron Ramirez - 06-14-2016, 04:43 PM
RE: Philco Superdyne 7 - by klondike98 - 06-14-2016, 06:36 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6406 online users. [Complete List]
» 1 Member(s) | 6405 Guest(s)
