37-610 volume pot acting funny
A few days ago, I went to the SARS spring meet in Atlanta. I traded my 38-62 for this 37-610. I told myself no more Philco's, but this is one I always liked. It was recapped before I got it. It has audio, but the volume control is very touchy. It only has one point where it's listenable - any lower and you can't here it at all, any higher, and it squeals like crazy. The cabinet it in pretty good shape, but the chassis is very dirty and needs lots of work. I tried spraying the pot, but it's sealed, and it made no difference.
Slave to an RCA Victor CTC-25
37-610 volume pot acting funny - by TheUniversalDave1 - 06-14-2016, 07:32 PM
