Philco model 90
  Did some more stripping today wit citristrip. Only found one flaw on the front just to the right of the escutcheon hole. I'm going to hit it with lacquer tomorrow morning. Too darn hot this afternoon, 99 deg. right now.
[Image: http://i1336.photobucket.com/albums/o654...o7pmig.jpg]
 It also looks like the paint acted as a grain filler so will have to use the lacquer to get it out.
[Image: http://i1336.photobucket.com/albums/o654...8n1jnw.jpg]
Philco model 90 - by KCMike - 06-13-2016, 12:02 PM
RE: Philco model 90 - by morzh - 06-13-2016, 12:33 PM
RE: Philco model 90 - by klondike98 - 06-13-2016, 05:06 PM
RE: Philco model 90 - by Paul Philco322 - 06-13-2016, 08:43 PM
RE: Philco model 90 - by OldRestorer - 06-14-2016, 08:19 AM
RE: Philco model 90 - by KCMike - 06-14-2016, 08:31 AM
RE: Philco model 90 - by morzh - 06-14-2016, 01:58 PM
RE: Philco model 90 - by KCMike - 06-14-2016, 04:27 PM
RE: Philco model 90 - by klondike98 - 06-14-2016, 04:39 PM
RE: Philco model 90 - by sdradioman - 06-14-2016, 08:06 PM
RE: Philco model 90 - by morzh - 06-14-2016, 09:47 PM
RE: Philco model 90 - by KCMike - 06-15-2016, 06:14 PM
RE: Philco model 90 - by Kenneth F. Besso Jr. - 06-15-2016, 07:24 PM
RE: Philco model 90 - by KCMike - 06-15-2016, 07:52 PM
RE: Philco model 90 - by KCMike - 06-17-2016, 03:00 PM
RE: Philco model 90 - by Art Hoch - 06-21-2016, 12:44 PM
RE: Philco model 90 - by KCMike - 06-22-2016, 04:54 PM
RE: Philco model 90 - by OldRestorer - 06-22-2016, 06:16 PM
RE: Philco model 90 - by KCMike - 06-22-2016, 07:05 PM
RE: Philco model 90 - by KCMike - 07-18-2016, 07:49 PM
RE: Philco model 90 - by morzh - 07-18-2016, 08:57 PM
RE: Philco model 90 - by KCMike - 07-18-2016, 09:30 PM
RE: Philco model 90 - by morzh - 07-18-2016, 09:41 PM
RE: Philco model 90 - by KCMike - 11-06-2016, 11:56 AM
RE: Philco model 90 - by morzh - 11-06-2016, 01:59 PM
RE: Philco model 90 - by klondike98 - 11-06-2016, 04:06 PM
RE: Philco model 90 - by Ron Ramirez - 11-06-2016, 04:32 PM
RE: Philco model 90 - by KCMike - 11-06-2016, 04:33 PM
RE: Philco model 90 - by OldRestorer - 11-06-2016, 07:04 PM
RE: Philco model 90 - by Kenneth F. Besso Jr. - 11-06-2016, 08:56 PM
RE: Philco model 90 - by KCMike - 11-06-2016, 09:18 PM
RE: Philco model 90 - by morzh - 11-06-2016, 11:11 PM
RE: Philco model 90 - by KCMike - 11-07-2016, 08:09 AM
RE: Philco model 90 - by OldRestorer - 11-07-2016, 03:29 PM
Philco 91 Tuning Condenser
There are currently 10146 online users. [Complete List]
» 1 Member(s) | 10145 Guest(s)
