Can anyone ID this radio?
I picked up this 5 tube for $10 at a flea mkt. It has nothing on it in regards to make or model. Can anyone ID it?
[Image: http://i.imgur.com/oYvu0eM.jpg]
Can anyone ID this radio? - by Tgace459 - 06-18-2016, 09:14 PM
RE: Can anyone ID this radio? - by Radioroslyn - 06-18-2016, 10:31 PM
RE: Can anyone ID this radio? - by Tgace459 - 06-18-2016, 10:37 PM
RE: Can anyone ID this radio? - by Tgace459 - 06-19-2016, 12:00 PM
RE: Can anyone ID this radio? - by Radioroslyn - 06-19-2016, 09:33 AM
RE: Can anyone ID this radio? - by Tgace459 - 06-19-2016, 09:35 AM
RE: Can anyone ID this radio? - by Tgace459 - 06-19-2016, 10:18 AM
RE: Can anyone ID this radio? - by 37silverstreak - 06-19-2016, 11:09 AM
RE: Can anyone ID this radio? - by Tgace459 - 06-19-2016, 11:46 AM
RE: Can anyone ID this radio? - by 37silverstreak - 06-19-2016, 12:14 PM
RE: Can anyone ID this radio? - by Tgace459 - 06-19-2016, 12:16 PM
RE: Can anyone ID this radio? - by Radioroslyn - 06-19-2016, 12:19 PM
RE: Can anyone ID this radio? - by Tgace459 - 06-19-2016, 12:23 PM
RE: Can anyone ID this radio? - by David - 06-19-2016, 09:42 PM
RE: Can anyone ID this radio? - by Tgace459 - 06-28-2016, 10:24 PM
RE: Can anyone ID this radio? - by Tgace459 - 06-28-2016, 10:25 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
