Atwater-Kent 60 console
I had to replace a grid clip on this one before I tried it out. It was loose on one of the 24's, so I lightly squeezed it and it crumbled. I would say a capacitor or resistor gave up the ghost as the sound just faded out and that was that. Checked the tubes, even swapped tubes with no change.
Atwater-Kent 60 console - by Jayce - 06-07-2016, 08:04 PM
RE: Atwater-Kent 60 console - by palegreenthumb - 06-18-2016, 03:33 AM
RE: Atwater-Kent 60 console - by Arran - 06-18-2016, 05:26 AM
RE: Atwater-Kent 60 console - by Phlogiston - 06-18-2016, 11:48 AM
RE: Atwater-Kent 60 console - by Jayce - 06-19-2016, 04:52 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6210 online users. [Complete List]
» 1 Member(s) | 6209 Guest(s)
