Unknown Philco
59S it is - four tubes. Thank you, everyone.
Unknown Philco - by dseverson - 06-20-2016, 04:50 PM
RE: Unknown Philco - by klondike98 - 06-20-2016, 05:07 PM
RE: Unknown Philco - by KCMike - 06-20-2016, 05:09 PM
RE: Unknown Philco - by KCMike - 06-20-2016, 05:10 PM
RE: Unknown Philco - by dseverson - 06-20-2016, 05:23 PM
RE: Unknown Philco - by Paul Philco322 - 06-20-2016, 08:32 PM
RE: Unknown Philco - by palegreenthumb - 06-23-2016, 02:46 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
