New to this; need a little input/ advice
I have a Philco Radio that seems to be intact. How can I pin down the year it is from? (I was unable to attach a photo due to the file size) Also, I am not sure if I should try to plug it in since I certainly do not wish to cause any damage to the electronics. Lastly, what is the best way to clean up the wood? I was going to use something like Murphy's Wood Polish. Any advice?
Bob Icon_smile
New to this; need a little input/ advice - by Guest - 07-17-2009, 11:08 AM
