.003mf caps on Philco 40-195
Really appreciate your response. Good idea about putting them in series. Unfortunately, I'm still having a hard time sourcing a .003 or .006 film capacitors at 1000 V DC. If I didn't want to use vintage looking caps it would be okay to use ceramic disc capacitors, right? They are much easier to come by. thanks again.
.003mf caps on Philco 40-195 - by dgarvin57 - 06-18-2016, 02:14 PM
RE: .003mf caps on Philco 40-195 - by Radioroslyn - 06-18-2016, 08:37 PM
RE: .003mf caps on Philco 40-195 - by dgarvin57 - 06-20-2016, 10:48 PM
RE: .003mf caps on Philco 40-195 - by Radioroslyn - 06-21-2016, 10:43 AM
RE: .003mf caps on Philco 40-195 - by Nick3092 - 06-21-2016, 02:55 PM
RE: .003mf caps on Philco 40-195 - by dgarvin57 - 06-24-2016, 12:33 AM
Restoring Philco 96
There are currently 7543 online users. [Complete List]
» 2 Member(s) | 7541 Guest(s)
