Big, Bad*s*, and ugly 660L
So out to the garage and grabbed the 84 chassis. Yielded a good 6 pin socket. Unsoldered the one in the 660 only to find I unsoldered the wrong one Dang it!!! Resolder wrong socket unsolder right socket, drill out rivets. Only to find that the hole spacing is a little off, about an 1/8". Elongate holes in socket to fit chassis holes. Used nylon screws and nuts to attach cuz I had them. Solder all connections and it's done for today.
Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-18-2016, 07:09 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-18-2016, 08:27 PM
RE: Big, Bad*s*, and ugly 660L - by OldRestorer - 06-18-2016, 08:33 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-18-2016, 08:45 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 12-01-2016, 09:07 PM
RE: Big, Bad*s*, and ugly 660L - by OldRestorer - 06-19-2016, 12:49 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-19-2016, 03:52 PM
RE: Big, Bad*s*, and ugly 660L - by KCMike - 06-19-2016, 04:11 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-19-2016, 04:54 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-20-2016, 08:50 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-20-2016, 11:47 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-21-2016, 06:30 AM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-21-2016, 03:45 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-22-2016, 02:44 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-22-2016, 06:56 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-24-2016, 01:25 PM
RE: Big, Bad*s*, and ugly 660L - by KCMike - 06-24-2016, 02:54 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-24-2016, 03:44 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-25-2016, 09:50 AM
RE: Big, Bad*s*, and ugly 660L - by KCMike - 06-25-2016, 10:36 AM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-25-2016, 01:34 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-25-2016, 07:41 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-26-2016, 08:33 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 06-30-2016, 02:01 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-03-2016, 10:00 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-07-2016, 05:20 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-07-2016, 11:31 PM
RE: Big, Bad*s*, and ugly 660L - by Arran - 07-08-2016, 03:47 AM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-08-2016, 08:35 AM
RE: Big, Bad*s*, and ugly 660L - by KCMike - 07-08-2016, 04:05 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-11-2016, 11:28 AM
RE: Big, Bad*s*, and ugly 660L - by morzh - 07-11-2016, 11:43 AM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-11-2016, 12:10 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-20-2016, 06:07 PM
RE: Big, Bad*s*, and ugly 660L - by OldRestorer - 07-20-2016, 08:26 PM
RE: Big, Bad*s*, and ugly 660L - by sam - 07-20-2016, 09:40 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 07-20-2016, 10:04 PM
RE: Big, Bad*s*, and ugly 660L - by sam - 07-20-2016, 10:52 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-27-2016, 05:16 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-27-2016, 07:39 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-28-2016, 07:22 PM
RE: Big, Bad*s*, and ugly 660L - by morzh - 11-28-2016, 09:24 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-28-2016, 09:56 PM
RE: Big, Bad*s*, and ugly 660L - by sam - 11-29-2016, 02:28 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-29-2016, 04:12 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-29-2016, 09:17 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-30-2016, 11:24 AM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-30-2016, 12:46 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 11-30-2016, 03:41 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 12-01-2016, 06:48 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 12-01-2016, 10:10 PM
RE: Big, Bad*s*, and ugly 660L - by Ron Ramirez - 12-02-2016, 11:02 PM
RE: Big, Bad*s*, and ugly 660L - by klondike98 - 12-02-2016, 11:30 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 12-03-2016, 03:32 PM
RE: Big, Bad*s*, and ugly 660L - by KCMike - 12-03-2016, 03:53 PM
RE: Big, Bad*s*, and ugly 660L - by Ron Ramirez - 12-03-2016, 04:51 PM
RE: Big, Bad*s*, and ugly 660L - by Radioroslyn - 12-03-2016, 05:00 PM
RE: Big, Bad*s*, and ugly 660L - by Ron Ramirez - 12-03-2016, 09:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4885 online users. [Complete List]
» 2 Member(s) | 4883 Guest(s)
