New to this; need a little input/ advice
We can't help you unless you need to give us a MODEL number, and any CODE number.
Then we can give you a manufacture date.
These can be on the sticker on the inside of the wood cabinet, or ink-stamped on the chassis rear apron.
There are some model sthat had the sticker on the chassis or a tube shield as well.
Chuck
New to this; need a little input/ advice - by Guest - 07-17-2009, 11:08 AM
Re: New to this; need a little input/ advice - by Chuck Schwark - 07-17-2009, 12:16 PM
