Philco Model 38 Code 123 Oscillator Problem
Hi Gene,
So your a rocket scientist!!!
I'm just a wiseguy!
I would reverse the connection on the ant primary. The diagram shows the top of the winding going to the ant post. Would also add some more turns say 25 total. Should be near the bottom of the secondary. You could add some C between the top of the pri and secondary like 10-50 mmfd.
Gl
RE: Philco Model 38 Code 123 Oscillator Problem - by Radioroslyn - 06-22-2016, 06:03 PM
Restoring Philco 96
There are currently 7571 online users. [Complete List]
» 2 Member(s) | 7569 Guest(s)
