Philco 48-200 Dial Face Cleaning
 I've used a number of things but an automotive hand cleaner like Gojo is usually safe on paint, and also works good on cleaning lacquer finishes and plastic, but get the cream kind without the pumice.
Philco 48-200 Dial Face Cleaning - by Tgace459 - 06-24-2016, 06:16 PM
RE: Philco 48-200 Dial Face Cleaning - by Arran - 06-25-2016, 05:50 AM
There are currently 10289 online users. [Complete List]
» 2 Member(s) | 10287 Guest(s)
