38-10 Won't Align Properly
Those padder capacitors often get gummed up and cn't do their jobs. I try to dis-assemble them, clean the mica very gently with water, the rest with deoxit, let the whole assembly dry down, re assemble then do the alignment. Hope this helps some.
38-10 Won't Align Properly - by Johnny - 07-17-2009, 05:55 PM
Re: 38-10 Won't Align Properly - by rghines1 - 07-18-2009, 02:04 PM
Re: 38-10 Won't Align Properly - by codefox1 - 07-18-2009, 02:22 PM
Re: 38-10 Won't Align Properly - by Johnny - 07-18-2009, 05:34 PM
There are currently 3593 online users. [Complete List]
» 2 Member(s) | 3591 Guest(s)
