Phono Connection for Philco Model 96
There's a few ways to go about it. Cheap and dirty is solder a .01 mfd cap to the junction of #28 &30. use the unsoldered end and the chassis for the input. Ground the ant post so you won't hear any radio signals.
You could add a radio /phono switch break the connection from 28 to 30. 28 is the audio output from the radio. 30 is the input to the amplifier. Use a switch to connect either the radio audio (28 ) or the phono to 30.
RE: Phono Connection for Philco Model 96 - by Radioroslyn - 06-25-2016, 07:21 PM
Restoring Philco 96
There are currently 7504 online users. [Complete List]
» 3 Member(s) | 7501 Guest(s)
