38-10 Won't Align Properly
Well I just love learning new stuff. Did a little more cleaning and slowly adjusted #7 and #9 and was able to bring the set in perfect. I guess I've been lucky on all my Philcos because I've never had to adjust anything but the IF's when aligning. In this case I kept moving the dial closer to the 1260 station and then adjusting 7 & 9 until the station came in clear. Finally I was at 1260 and it tuned in great. All other stations are where they're supposed to be also.
Thanks for the help. Always appreciated.
Johnny
38-10 Won't Align Properly - by Johnny - 07-17-2009, 05:55 PM
Re: 38-10 Won't Align Properly - by rghines1 - 07-18-2009, 02:04 PM
Re: 38-10 Won't Align Properly - by codefox1 - 07-18-2009, 02:22 PM
Re: 38-10 Won't Align Properly - by Johnny - 07-18-2009, 05:34 PM
There are currently 3476 online users. [Complete List]
» 1 Member(s) | 3475 Guest(s)
