Philco 90
Compare your tube layout to determine if you have an early or mid chassis:
http://www.philcorepairbench.com/cathedralid.htm
If an early chassis (p-p 45's) you need an H-2 speaker.  A mid version (single 47) uses an H-3 speaker.
There is a guy on eBay that sells pretty good reproduction tube shields:
http://www.ebay.com/itm/PHILCO-90-TUBE-S...7675.l2557
You might also want to look for a pair of copper Mershon filter capacitors to re-stuff and replace the two modern replacements on your chassis:
http://mcclellans.com/Philco90Restoration.htm
Philco 90 - by PhilcoPhan1936 - 06-26-2016, 08:44 PM
RE: Philco 90 - by Eliot Ness - 06-26-2016, 09:42 PM
RE: Philco 90 - by PhilcoPhan1936 - 06-27-2016, 12:32 AM
RE: Philco 90 - by Radioroslyn - 06-26-2016, 11:11 PM
RE: Philco 90 - by PhilcoPhan1936 - 06-27-2016, 12:35 AM
RE: Philco 90 - by markmokris - 06-28-2016, 03:31 PM
RE: Philco 90 - by morzh - 06-27-2016, 11:59 AM
RE: Philco 90 - by Radioroslyn - 06-27-2016, 12:59 PM
RE: Philco 90 - by PhilcoPhan1936 - 06-27-2016, 08:10 PM
RE: Philco 90 - by Radioroslyn - 06-27-2016, 12:53 PM
RE: Philco 90 - by PhilcoPhan1936 - 06-27-2016, 08:08 PM
RE: Philco 90 - by Ron Ramirez - 06-27-2016, 01:35 PM
RE: Philco 90 - by PhilcoPhan1936 - 06-27-2016, 08:04 PM
RE: Philco 90 - by morzh - 06-27-2016, 10:45 PM
RE: Philco 90 - by Radioroslyn - 06-28-2016, 06:42 PM
RE: Philco 90 - by markmokris - 06-29-2016, 04:15 PM
RE: Philco 90 - by Eliot Ness - 06-29-2016, 04:39 PM
RE: Philco 90 - by markmokris - 06-29-2016, 06:06 PM
RE: Philco 90 - by Eliot Ness - 06-29-2016, 10:12 PM
RE: Philco 90 - by markmokris - 06-29-2016, 11:13 PM
RE: Philco 90 - by PhilcoPhan1936 - 06-30-2016, 04:11 PM
RE: Philco 90 - by markmokris - 07-01-2016, 09:32 AM
Restoring Philco 96
There are currently 7810 online users. [Complete List]
» 2 Member(s) | 7808 Guest(s)
