Intermittent volume model 25 chassis
I fully rebuilt a model 20 chassis. I played it outside of the cabinet for several hours over a period of several days. I only had a wire antenna of about 15' and the radio played great. I installed it inside of the cabinet and it played very well for over a week. then suddenly, one day the volume dropped way down to barely audible. I discovered that the first 24 RF tube was defective. This brought the volume back to normal. then I began to notice that the volume would drop lower on its own and sometimes when a light or an appliance would come on the volume would return to normal. These are all on separate electrical circuits. I attached wires to the major B+ points and was going to monitor them, with the chassis in the cabinet. However whenever I would touch the meter probe to any wire, the volume would come back to normal. Easy right? Bad filters or rectifier? So I rebuilt the filter capacitor can with all new components and replaced the rectifier. (All tubes have also been changed.) Still the volume will drop slightly lower and then on its own come back full again. I took the chassis out of the cabinet and attached the signal tracer probe to the input grid of the first AF tube and placed the chassis bottom side down to build up the heat. The radio played for four days, no problems and it also played through the tracer without a single problem. I reinstalled the radio in the cabinet and the problem returned. You can still hear the radio playing when the volume drops, but it's annoying, when it comes back up on its own. Any ideas or is this something that happens to a TRF receiver? The radio has been tried on a number of different stations with the same results. Sorry guys this is my first experience with a TRF set.
Intermittent volume model 25 chassis - by Tubesforme - 06-27-2016, 03:47 PM
There are currently 6384 online users. [Complete List]
» 1 Member(s) | 6383 Guest(s)
