Intermittent volume model 25 chassis
Check all the ground connections where lugs are riveted to the chassis. Also, check the screws on the tuning condenser that hold the stator assemblies in place. Loosen each screw, one at a time and retighten.
M R Radios   C M Tubes
RE: Intermittent volume model 25 chassis - by Steve Davis - 06-27-2016, 05:00 PM
