10 radio cabinet restoration chronicles
#31
Kirk good job I like your work!!
RE: 10 radio cabinet restoration chronicles - by PhilcoJohn - 06-27-2016, 06:31 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
