I don't believe it!
kruc Wrote:Good find on those dried out caps there Chris. The internet is your friend when looking for unusual caps like you have in that chassis. AES, Digikey, Mouser, All Electronics, Fair Radio, Surplus Sales of Nebraska, and others I'm brainfarting about right now. Also there might be a yayhoo group dedicated to old Marantz gear. Just remember that electrolytic caps are polarized and will vent or explode if wired in reverse. Put a piece of tape or some other marker like a tie wrap to mark the positive lead. A lot of people have learned this the hard way.
Dave
These I think are going to be hard to nail down because they are super skinny and tall and fit into holder compartments! Wish me luck.
tractorforum.com *** I reserve the right to be wrong
I don't believe it! - by Music in a bottle - 07-12-2009, 10:22 PM
Re: I don't believe it! - by Texasrocker - 07-13-2009, 03:19 AM
Re: I don't believe it! - by Music in a bottle - 07-13-2009, 02:23 PM
Re: I don't believe it! - by Arran - 07-14-2009, 12:29 AM
Re: I don't believe it! - by kruc - 07-15-2009, 04:02 AM
Re: I don't believe it! - by Texasrocker - 07-16-2009, 03:01 AM
Re: I don't believe it! - by Music in a bottle - 07-19-2009, 05:37 PM
Re: I don't believe it! - by Music in a bottle - 07-19-2009, 05:39 PM
Re: I don't believe it! - by codefox1 - 07-19-2009, 05:54 PM
Re: I don't believe it! - by Music in a bottle - 07-19-2009, 10:37 PM
Re: I don't believe it! - by kruc - 07-20-2009, 05:07 AM
Philco 91 Tuning Condenser
There are currently 8507 online users. [Complete List]
» 1 Member(s) | 8506 Guest(s)
