Philco 640 - Need Some Help
The voltages on the 42 tubes are as follows:
1st 42
Pin 2: 262V
Pin 3: 275V
Pin 4: -16.9V
Pin 5: 0V
2nd 42
Pin 2: 267V
Pin 3: 273V
Pin 4: -16.7V
Pin 5: 0V
Philco 640 - Need Some Help - by Geoff - 06-29-2016, 06:07 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 06-29-2016, 07:52 PM
RE: Philco 640 - Need Some Help - by Geoff - 06-29-2016, 08:05 PM
RE: Philco 640 - Need Some Help - by Geoff - 06-30-2016, 02:37 AM
RE: Philco 640 - Need Some Help - by Radioroslyn - 06-30-2016, 07:45 AM
RE: Philco 640 - Need Some Help - by Steve Davis - 06-30-2016, 10:06 AM
RE: Philco 640 - Need Some Help - by markmokris - 07-01-2016, 11:59 AM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:00 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:01 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:02 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:04 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:10 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:16 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 07-01-2016, 07:19 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 07:20 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 07-01-2016, 08:19 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-02-2016, 01:02 AM
RE: Philco 640 - Need Some Help - by Geoff - 08-04-2016, 06:39 PM
RE: Philco 640 - Need Some Help - by Geoff - 08-04-2016, 08:08 PM
Philco 640 Shadow Meter Bulb Type - by Geoff - 08-04-2016, 07:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7137 online users. [Complete List]
» 3 Member(s) | 7134 Guest(s)
