Philco 640 - Need Some Help
(06-29-2016, 07:52 PM)Radioroslyn Wrote:  Hi Geoff,
Voltages all look pretty good. I'd dump a signal down the If  at the cap of the IF amp (78 ) at 460kc and hear what comes out of the spkr. If that goes well then move the generator to the grid cap of the 6A7 and align the IF transformers. Seems like your LO is working as you have negative voltage on grid 1 of the 6A7. Just to be sure take a look at the voltage found grid 1 to the chassis on each 42 tubes. Should see -15vdc or so. Touch the cap on the 85 tube spkr should emit a loud buzz.
I do get a loud buzz when touching the grid cap on the 85 tube.
Philco 640 - Need Some Help - by Geoff - 06-29-2016, 06:07 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 06-29-2016, 07:52 PM
RE: Philco 640 - Need Some Help - by Geoff - 06-29-2016, 08:05 PM
RE: Philco 640 - Need Some Help - by Geoff - 06-30-2016, 02:37 AM
RE: Philco 640 - Need Some Help - by Radioroslyn - 06-30-2016, 07:45 AM
RE: Philco 640 - Need Some Help - by Steve Davis - 06-30-2016, 10:06 AM
RE: Philco 640 - Need Some Help - by markmokris - 07-01-2016, 11:59 AM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:00 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:01 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:02 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:04 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:10 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:16 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 07-01-2016, 07:19 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 07:20 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 07-01-2016, 08:19 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-02-2016, 01:02 AM
RE: Philco 640 - Need Some Help - by Geoff - 08-04-2016, 06:39 PM
RE: Philco 640 - Need Some Help - by Geoff - 08-04-2016, 08:08 PM
Philco 640 Shadow Meter Bulb Type - by Geoff - 08-04-2016, 07:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9043 online users. [Complete List]
» 3 Member(s) | 9040 Guest(s)
