Philco 640 - Need Some Help
Just so you know this is just a hobby for me too but have been at it for 50yrs or so.
Your screen voltage for the mixer and if amp is too low. Check #64 too high in resistance, 79 too low in resistance,and 68 leaky or shorted.
If values are ok then pull 78 and check sg voltage then pull the 6a7 and measure the sg voltage. If it goes up significantly then substitute the tube.
Philco 640 - Need Some Help - by Geoff - 06-29-2016, 06:07 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 06-29-2016, 07:52 PM
RE: Philco 640 - Need Some Help - by Geoff - 06-29-2016, 08:05 PM
RE: Philco 640 - Need Some Help - by Geoff - 06-30-2016, 02:37 AM
RE: Philco 640 - Need Some Help - by Radioroslyn - 06-30-2016, 07:45 AM
RE: Philco 640 - Need Some Help - by Steve Davis - 06-30-2016, 10:06 AM
RE: Philco 640 - Need Some Help - by markmokris - 07-01-2016, 11:59 AM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:00 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:01 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:02 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:04 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:10 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 04:16 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 07-01-2016, 07:19 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-01-2016, 07:20 PM
RE: Philco 640 - Need Some Help - by Radioroslyn - 07-01-2016, 08:19 PM
RE: Philco 640 - Need Some Help - by Geoff - 07-02-2016, 01:02 AM
RE: Philco 640 - Need Some Help - by Geoff - 08-04-2016, 06:39 PM
RE: Philco 640 - Need Some Help - by Geoff - 08-04-2016, 08:08 PM
Philco 640 Shadow Meter Bulb Type - by Geoff - 08-04-2016, 07:04 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5342 online users. [Complete List]
» 3 Member(s) | 5339 Guest(s)
