Bakelite?
Hey Doug,
Thanks for the fast response! I figured it was probably 50's due to the style clock, but hadn't seen the plastic. It's a really pretty case and the ring on the clock face is a kind of mother-of-pearl look -- a pretty unique combo I have to say. I'm going to restore it and finally replace that cheap piece of junk alarm clock I have on my nightstand!
Thanks again,
Joe
"Ignorance is bliss...'til you have to fix a radio..."
Bakelite? - by jayoungs - 07-19-2009, 11:45 PM
Re: Bakelite? - by Doug Houston - 07-19-2009, 11:51 PM
Re: Bakelite? - by jayoungs - 07-20-2009, 12:02 AM
Re: Bakelite? - by Texasrocker - 07-20-2009, 01:11 AM
Re: Bakelite? - by Arran - 07-20-2009, 04:51 AM
Re: Bakelite? - by jayoungs - 07-20-2009, 12:31 PM
Re: Bakelite? - by philco phan - 07-21-2009, 04:18 PM
Re: Bakelite? - by Doug Houston - 07-30-2009, 10:26 PM
Re: Bakelite? - by jayoungs - 07-31-2009, 12:31 PM
Re: Bakelite? - by Guest - 03-27-2010, 10:46 AM
