Dial cord for Philco 118
KCMike,
  Thanks for posting that. I had no idea at all.
 Mike M.
 GC Electronics lists heavy dial cord as 0.062 " thick , med 0.040" and thin was .028" That info was from a 1954 radio catalogue. The Philco info says thick dial cord was used.
                                      Henry
Dial cord for Philco 118 - by morzh - 07-01-2016, 08:58 PM
RE: Dial cord for Philco 118 - by Arran - 07-02-2016, 04:41 AM
RE: Dial cord for Philco 118 - by morzh - 07-02-2016, 03:35 PM
RE: Dial cord for Philco 118 - by Arran - 07-03-2016, 03:14 AM
RE: Dial cord for Philco 118 - by radiohenry - 07-03-2016, 08:52 AM
RE: Dial cord for Philco 118 - by KCMike - 07-03-2016, 09:04 AM
RE: Dial cord for Philco 118 - by radiohenry - 07-03-2016, 12:19 PM
RE: Dial cord for Philco 118 - by Warren - 07-03-2016, 01:18 PM
RE: Dial cord for Philco 118 - by morzh - 07-03-2016, 11:06 PM
There are currently 3986 online users. [Complete List]
» 1 Member(s) | 3985 Guest(s)
