GE Model A-64
I am looking for any information on a GE A-64 Tube radio.. I have a chance to pick one up for about 75 dollars and want to know if that's worth it.. Its 540-1800 KC and 5400-18000 kc 6 tubes.. Anyone have any info on this.. Problems good bad?? ETC.. I did download a schematic from Riders but it really not to clear...
Thanks
Skip
GE Model A-64 - by vecher - 07-03-2016, 03:43 PM
RE: GE Model A-64 - by Phlogiston - 07-03-2016, 05:59 PM
RE: GE Model A-64 - by vecher - 07-03-2016, 08:18 PM
RE: GE Model A-64 - by Radioroslyn - 07-03-2016, 10:29 PM
RE: GE Model A-64 - by vecher - 07-03-2016, 10:44 PM
RE: GE Model A-64 - by Arran - 07-04-2016, 04:40 AM
RE: GE Model A-64 - by Phlogiston - 07-04-2016, 10:09 AM
RE: GE Model A-64 - by vecher - 07-04-2016, 10:42 AM
RE: GE Model A-64 - by Kenneth F. Besso Jr. - 07-04-2016, 01:59 PM
RE: GE Model A-64 - by vecher - 07-04-2016, 02:34 PM
RE: GE Model A-64 - by vecher - 07-04-2016, 03:17 PM
RE: GE Model A-64 - by KCMike - 07-04-2016, 04:05 PM
RE: GE Model A-64 - by vecher - 07-04-2016, 04:14 PM
RE: GE Model A-64 - by KCMike - 07-04-2016, 05:03 PM
RE: GE Model A-64 - by vecher - 07-04-2016, 06:10 PM
RE: GE Model A-64 - by vecher - 07-05-2016, 01:43 PM
RE: GE Model A-64 - by Phlogiston - 07-05-2016, 04:59 PM
RE: GE Model A-64 - by vecher - 07-05-2016, 06:03 PM
RE: GE Model A-64 - by Phlogiston - 07-06-2016, 11:35 AM
RE: GE Model A-64 - by Arran - 07-06-2016, 04:05 AM
RE: GE Model A-64 - by vecher - 07-06-2016, 12:22 PM
RE: GE Model A-64 - by vecher - 07-07-2016, 09:02 AM
RE: GE Model A-64 - by Arran - 07-10-2016, 05:02 AM
RE: GE Model A-64 - by vecher - 07-10-2016, 08:55 AM
RE: GE Model A-64 - by Arran - 07-12-2016, 04:14 AM
RE: GE Model A-64 - by vecher - 07-12-2016, 11:54 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
