37-640 RF Deck
I finished the chassis on my 37-640, pulled the RF Deck, reinstalled it with new soft grommets, but it still seams quite rigidly held in the chassis. I am curious what electronic advantage was obtained by building the radio this way, reduction of microphonics ?.
Hank
37-640 RF Deck - by Hank G - 07-03-2016, 04:38 PM
RE: 37-640 RF Deck - by jerryhawthorne - 07-03-2016, 06:52 PM
RE: 37-640 RF Deck - by Ron Ramirez - 07-03-2016, 10:54 PM
There are currently 6627 online users. [Complete List]
» 1 Member(s) | 6626 Guest(s)
