Philco Model 71 Code 121 console value?
Depends where it is but in general my guess is close to Arran's. And it is in great shape, I would pay $120 without haggling for it were it being sold in NJ.
RE: Philco Model 71 Code 121 console value? - by morzh - 07-03-2016, 11:11 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6613 online users. [Complete List]
» 1 Member(s) | 6612 Guest(s)
