philco 116x-122 band selector cord routing and set up
My shaft is bent upwards that the knob fits on.  Has anybody bent it back.  Its bent at the large U part of the bracket assembly.  The either pot metal or aluminum.  Im not sure if I should attempt to bend it back.
I started collecting radios when I was a kid.......never kept any of them.  Always messed them up(didnt know what I was doing)  Sucessfully bought my first radio and got it working in 1995in california, and carried it home on a 3 day train ride.  It was a philco 38 code 123 battery operated farm set.
RE: philco 116x-122 band selector cord routing and set up - by quartermilecamel - 07-04-2016, 01:10 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 4394 online users. [Complete List]
» 2 Member(s) | 4392 Guest(s)
