philco 116x-122 band selector cord routing and set up
I used just regular size cord. I think it's .025". You maybe able to find a stronger spring at the hardware in one of those cabinets with the small parts in them.
RE: philco 116x-122 band selector cord routing and set up - by Radioroslyn - 07-04-2016, 06:34 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7195 online users. [Complete List]
» 3 Member(s) | 7192 Guest(s)
