  • 1 Vote(s) - 3 Average
SOS for ID; wanting to rebuild
Welcome to the Phorum!
Icon_wave
I've reposted your pictures so folks can see them directly:
[Image: https://dl.dropboxusercontent.com/u/5462...G_4629.jpg]
[Image: https://dl.dropboxusercontent.com/u/5462...G_4627.jpg]
[Image: https://dl.dropboxusercontent.com/u/5462...G_4626.jpg]
RE: SOS for ID; wanting to rebuild - by klondike98 - 07-06-2016, 12:39 PM
RE: SOS for ID; wanting to rebuild - by sam - 07-06-2016, 12:42 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
