Dial String pulley
A junker chassis, perhaps? Just about any of the larger 1939-42 models, or even some of the postwar models, should yield some pulleys.
Dial String pulley - by Jon Scaptura - 01-04-2006, 01:41 PM
[No subject] - by Ron Ramirez - 01-08-2006, 12:39 AM
[No subject] - by Jon Scaptura - 01-09-2006, 11:59 AM
There are currently 10248 online users. [Complete List]
» 2 Member(s) | 10246 Guest(s)
