48-1276?
Hi OldRestorer, I didn't count the caps but there are a lot of them. On my 48-1274, I didn't have to replace any resistors but there was a bad ground that was causing hum. I attached pictures attached but they are a little fuzzy. The magnetic cartridge on my M-4 is good and I have quite a few 78 RPM records to play on it. The FM section in my receiver pulls in many stations with it's internal dipole antenna and it isn't distorted sounding compared to other Philco radios with the FM1000 detector tube. It was a challenging restore to say the least.   Ken
48-1276? - by sdradioman - 05-26-2016, 10:52 AM
RE: 48-1276? - by Art Hoch - 05-27-2016, 05:58 PM
RE: 48-1276? - by sdradioman - 05-27-2016, 07:16 PM
RE: 48-1276? - by OldRestorer - 05-28-2016, 11:12 AM
RE: 48-1276? - by Ron Ramirez - 05-28-2016, 12:11 PM
RE: 48-1276? - by sdradioman - 05-28-2016, 02:29 PM
RE: 48-1276? - by sdradioman - 05-29-2016, 01:44 PM
RE: 48-1276? - by sdradioman - 05-29-2016, 01:46 PM
RE: 48-1276? - by KCMike - 05-29-2016, 06:13 PM
RE: 48-1276? - by w4rtc - 05-29-2016, 08:20 PM
RE: 48-1276? - by Kenradio - 07-09-2016, 06:39 AM
RE: 48-1276? - by OldRestorer - 07-09-2016, 11:00 AM
RE: 48-1276? - by Joe Rossi - 07-09-2016, 07:16 PM
RE: 48-1276? - by Kenradio - 07-09-2016, 07:33 PM
RE: 48-1276? - by sdradioman - 07-10-2016, 10:50 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
