Radio ID..
ALL, Here are 3 pictures of radios that have NO markings on them that I can find.. Anyone know the Model Numbers and years?
Thanks
Skip...
[Image: http://i292.photobucket.com/albums/mm38/...3gicsw.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...9uuu5w.jpg]
[Image: http://i292.photobucket.com/albums/mm38/...32xt2r.jpg]
Radio ID.. - by vecher - 07-10-2016, 03:21 PM
RE: Radio ID.. - by Radioroslyn - 07-10-2016, 03:33 PM
RE: Radio ID.. - by vecher - 07-10-2016, 06:32 PM
RE: Radio ID.. - by OldRestorer - 07-10-2016, 06:43 PM
RE: Radio ID.. - by Paul Philco322 - 07-10-2016, 07:29 PM
RE: Radio ID.. - by vecher - 07-10-2016, 08:07 PM
RE: Radio ID.. - by vecher - 07-11-2016, 12:37 AM
RE: Radio ID.. - by Kenneth F. Besso Jr. - 07-11-2016, 09:40 PM
RE: Radio ID.. - by Arran - 07-12-2016, 04:05 AM
RE: Radio ID.. - by vecher - 07-13-2016, 05:03 PM
RE: Radio ID.. - by KCMike - 07-13-2016, 06:23 PM
RE: Radio ID.. - by vecher - 07-15-2016, 12:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
