Philco 118
So it was the AVC. I accidentally connected cap #17 to the bottom pin of the RF xfmr #12 instead of the middle pin.
No wonder it attenuated the heck out of everything.
I walked down the AVC circuit and noticed the 2M and 70K resistor, where they connect to the coil, had no cap connected. That was the clue Icon_smile
Anyways, it plays very well now, the sound is really booming.
Philco 118 - by morzh - 05-24-2016, 09:07 PM
RE: Philco 118 - by KCMike - 05-24-2016, 09:35 PM
RE: Philco 118 - by morzh - 05-24-2016, 09:44 PM
RE: Philco 118 - by gregb - 05-24-2016, 10:17 PM
RE: Philco 118 - by morzh - 05-25-2016, 07:09 AM
RE: Philco 118 - by Eliot Ness - 05-25-2016, 07:46 AM
RE: Philco 118 - by klondike98 - 05-25-2016, 12:06 PM
RE: Philco 118 - by morzh - 05-25-2016, 02:15 PM
RE: Philco 118 - by morzh - 05-30-2016, 09:04 PM
RE: Philco 118 - by morzh - 06-01-2016, 09:51 PM
RE: Philco 118 - by morzh - 06-01-2016, 09:54 PM
RE: Philco 118 - by morzh - 06-01-2016, 09:57 PM
RE: Philco 118 - by KCMike - 06-01-2016, 10:04 PM
RE: Philco 118 - by morzh - 06-01-2016, 10:26 PM
RE: Philco 118 - by morzh - 06-09-2016, 10:04 PM
RE: Philco 118 - by morzh - 06-12-2016, 11:21 PM
RE: Philco 118 - by Arran - 06-13-2016, 04:23 AM
RE: Philco 118 - by morzh - 06-13-2016, 10:57 AM
RE: Philco 118 - by Arran - 06-15-2016, 04:00 AM
RE: Philco 118 - by morzh - 06-13-2016, 09:21 PM
RE: Philco 118 - by morzh - 06-15-2016, 08:06 AM
RE: Philco 118 - by morzh - 06-27-2016, 12:03 PM
RE: Philco 118 - by morzh - 07-02-2016, 11:51 PM
RE: Philco 118 - by morzh - 07-08-2016, 04:30 PM
RE: Philco 118 - by morzh - 07-10-2016, 07:39 PM
RE: Philco 118 - by morzh - 07-11-2016, 10:36 PM
RE: Philco 118 - by morzh - 07-13-2016, 09:09 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 5351 online users. [Complete List]
» 3 Member(s) | 5348 Guest(s)
