ID of Philco's
 The first set could also be a 48-1201, which was the same set but with some miniature tubes, and slug tuned IF cans, I believe that the B+ voltage was higher as well.
http://www.philcoradio.com/gallery/1948a.htm#w
 The console is a 46-1209 and the last set is a 46-350, unless it has an imitation alligator covering then it would be a 48-360.
ID of Philco's - by vecher - 07-10-2016, 03:18 PM
RE: ID of Philco's - by Radioroslyn - 07-10-2016, 03:43 PM
RE: ID of Philco's - by vecher - 07-10-2016, 06:35 PM
RE: ID of Philco's - by Arran - 07-11-2016, 03:35 AM
RE: ID of Philco's - by vecher - 07-11-2016, 06:16 PM
RE: ID of Philco's - by vecher - 07-15-2016, 12:26 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
