Philco 48-200 Clear but faint
There was/is a resistor (470,000 ohm if I recall correctly) and a .22 cap attached to pin 6 of the output tube....any idea where they "should" go? When I replaced the stuff that was in place I had my problem. I wonder if (as was mentioned earlier) someone else didn't tinker with this years back (it was an old Philco cap that was in place though).
This was the model with the 5OA5 output tube. I see there are 2 different tube versions and schematics for this model.
Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 09:18 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-01-2016, 10:08 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 10:57 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 11:03 PM
RE: Philco 48-200 Clear but faint - by leftwing25 - 07-02-2016, 01:06 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-01-2016, 11:28 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-04-2016, 04:03 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-06-2016, 08:53 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-08-2016, 11:37 PM
RE: Philco 48-200 Clear but faint - by David - 07-10-2016, 09:20 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-10-2016, 10:11 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-11-2016, 09:25 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 09:56 AM
RE: Philco 48-200 Clear but faint - by morzh - 07-11-2016, 11:45 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:41 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:05 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:26 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-21-2016, 07:37 AM
RE: Philco 48-200 Clear but faint - by morzh - 07-21-2016, 01:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8712 online users. [Complete List]
» 3 Member(s) | 8709 Guest(s)
