Philco 48-200 Clear but faint
So here's the problem, pin 6 is the control grid of the 50A5. If you connect the .22 to it and the chassis it passes most of the audio to ground. Remove that .22 from pin 6 and connect it from B- (- side of the filter) and the other end to the chassis as per the schematic. Leave the .01 and the 470k resistor.
Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 09:18 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-01-2016, 10:08 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 10:57 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 11:03 PM
RE: Philco 48-200 Clear but faint - by leftwing25 - 07-02-2016, 01:06 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-01-2016, 11:28 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-04-2016, 04:03 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-06-2016, 08:53 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-08-2016, 11:37 PM
RE: Philco 48-200 Clear but faint - by David - 07-10-2016, 09:20 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-10-2016, 10:11 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-11-2016, 09:25 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 09:56 AM
RE: Philco 48-200 Clear but faint - by morzh - 07-11-2016, 11:45 AM
RE: Philco 48-200 Clear but faint - by Radioroslyn - 07-11-2016, 11:58 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:41 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:05 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:26 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-21-2016, 07:37 AM
RE: Philco 48-200 Clear but faint - by morzh - 07-21-2016, 01:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7593 online users. [Complete List]
» 3 Member(s) | 7590 Guest(s)
