07-11-2016, 12:21 PM
It's a good time to measure any resistors that where connected with a cap across it. Whether you remove the block all together or leave it in the push the innards out. When you have a cap and a resistor in parallel and try to measure it with an ohmmeter there is a small voltage across the probes. This voltage will charge the cap and won't give you the proper resistance reading. In series your OK.
