Philco 48-200 Clear but faint
(07-11-2016, 11:58 AM)Radioroslyn Wrote:  So here's the problem, pin 6 is the control grid of the 50A5. If you connect the .22 to it and the chassis it passes most of the audio to ground. Remove that .22 from pin 6 and connect it from B- (- side of the filter) and the other end  to the chassis as per the schematic. Leave the .01 and the 470k resistor.
If I'm remembering correctly, I believe that all the filters are grounded to pin 4 of 14A7 (right next to where the .22 is/was attached now). There's a ton of wires and leads attached to pin 4. I'm impressed the manufacturers were able to do it. I do recall that it wasn't the pin the "troubleshooting" section of the schematic showed it to be.
This radio also had a three section cap with one (20 mfd) lead cut and a separate 20mfd installed. I assume it was a repair/replacement.
So attach .22 to pin 4 14A7 then to another convenient ground pin?
Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 09:18 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-01-2016, 10:08 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 10:57 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-01-2016, 11:03 PM
RE: Philco 48-200 Clear but faint - by leftwing25 - 07-02-2016, 01:06 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-01-2016, 11:28 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-04-2016, 04:03 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-06-2016, 08:53 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-08-2016, 11:37 PM
RE: Philco 48-200 Clear but faint - by David - 07-10-2016, 09:20 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-10-2016, 10:11 PM
RE: Philco 48-200 Clear but faint - by morzh - 07-11-2016, 09:25 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 09:56 AM
RE: Philco 48-200 Clear but faint - by morzh - 07-11-2016, 11:45 AM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:41 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:05 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-11-2016, 01:26 PM
RE: Philco 48-200 Clear but faint - by Tgace459 - 07-21-2016, 07:37 AM
RE: Philco 48-200 Clear but faint - by morzh - 07-21-2016, 01:05 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8782 online users. [Complete List]
» 3 Member(s) | 8779 Guest(s)
