Philco 59S Help
Looks like a scrunched up model 84. You know real voltmeters don't use batteries.
Philco 59S Help - by dseverson - 07-13-2016, 09:16 PM
RE: Philco 59S Help - by morzh - 07-13-2016, 09:38 PM
RE: Philco 59S Help - by Radioroslyn - 07-13-2016, 10:33 PM
RE: Philco 59S Help - by morzh - 07-13-2016, 10:52 PM
RE: Philco 59S Help - by dseverson - 07-13-2016, 11:28 PM
RE: Philco 59S Help - by Radioroslyn - 07-13-2016, 11:50 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8957 online users. [Complete List]
» 3 Member(s) | 8954 Guest(s)
