RCA R-8 Chassis Rebuild
If anyone is interested, I just posted a pictorial of this much despised chassis being rebuilt on my blog:
http://www.russoldradios.com/blog
Most people hate it. Not because it works poorly but because it is very difficult to work on. I have done several of these since they were used with a few changes for 2 years in many RCA and GE (Westinghouse?) radios. The same chassis was used in consoles and table models with the same speaker. There were also 7 and 9 tube versions.
Russ
RCA R-8 Chassis Rebuild - by Phlogiston - 07-15-2016, 10:48 AM
RE: RCA R-8 Chassis Rebuild - by KCMike - 07-15-2016, 12:16 PM
RE: RCA R-8 Chassis Rebuild - by Eliot Ness - 07-15-2016, 03:17 PM
RE: RCA R-8 Chassis Rebuild - by klondike98 - 07-15-2016, 07:05 PM
RE: RCA R-8 Chassis Rebuild - by Paul Philco322 - 07-15-2016, 09:27 PM
RE: RCA R-8 Chassis Rebuild - by Arran - 07-16-2016, 04:22 AM
RE: RCA R-8 Chassis Rebuild - by Phlogiston - 07-16-2016, 11:03 AM
RE: RCA R-8 Chassis Rebuild - by palegreenthumb - 07-16-2016, 04:28 AM
RE: RCA R-8 Chassis Rebuild - by Phlogiston - 07-16-2016, 10:57 AM
RE: RCA R-8 Chassis Rebuild - by Arran - 07-18-2016, 03:13 AM
RE: RCA R-8 Chassis Rebuild - by Phlogiston - 07-18-2016, 11:01 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
