Radio ID..
All, I picked up all three radios for 25.00 each.. The Stromberg cabinet is the best of all.
The parts alone are probably worth more than I paid..
Thanks all for your help..
Skip...
Radio ID.. - by vecher - 07-10-2016, 03:21 PM
RE: Radio ID.. - by Radioroslyn - 07-10-2016, 03:33 PM
RE: Radio ID.. - by vecher - 07-10-2016, 06:32 PM
RE: Radio ID.. - by OldRestorer - 07-10-2016, 06:43 PM
RE: Radio ID.. - by Paul Philco322 - 07-10-2016, 07:29 PM
RE: Radio ID.. - by vecher - 07-10-2016, 08:07 PM
RE: Radio ID.. - by vecher - 07-11-2016, 12:37 AM
RE: Radio ID.. - by Kenneth F. Besso Jr. - 07-11-2016, 09:40 PM
RE: Radio ID.. - by Arran - 07-12-2016, 04:05 AM
RE: Radio ID.. - by vecher - 07-13-2016, 05:03 PM
RE: Radio ID.. - by KCMike - 07-13-2016, 06:23 PM
RE: Radio ID.. - by vecher - 07-15-2016, 12:30 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6307 online users. [Complete List]
» 1 Member(s) | 6306 Guest(s)
