Model 70 speaker transformer wireing
Michael
You were told correctly, the 2766 transformer from 20 is used both as push-pull (like in 20 for 71A or in some later models for 45) and an SE (for 42/47 tubes). It has the ratio of 100:1 and is used for 0.65 Ohm voice coil impedance.
The 2673 transformer, that is used in 70 model, has 90:1 ratio and is used for 0.85 Ohm voice coils.
These are pretty close and the 2766 would work just fine in a 70.
RE: Model 70 speaker transformer wireing - by morzh - 07-15-2016, 04:50 PM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3729 online users. [Complete List]
» 3 Member(s) | 3726 Guest(s)
