Model 70 speaker transformer wireing
Mike, I do agree, the impedance match of a 20 speaker and output transformer is close enough. But, in order to achieve a close match, the plug should be rewired so the B+ is connected to the end of the primary rather than the center tap.
M R Radios   C M Tubes
RE: Model 70 speaker transformer wireing - by Steve Davis - 07-16-2016, 10:54 AM
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7784 online users. [Complete List]
» 3 Member(s) | 7781 Guest(s)
