Philco 60 - Problem with Short Wave/Police Band
Not a whole lot can go wrong here. Make sure the bandswitch contacts for the coils are both doing their job in shorting out a section of the coil.
On the mica cap Philco uses their own color code. Details can be found on Chuck's site.
GL,
Bill
91H Code 126 Restore
The speaker table error?
Philco 70 antenna lead
There are currently 5430 online users. [Complete List]
» 1 Member(s) | 5429 Guest(s)
