Philco 60 - Problem with Short Wave/Police Band
Also be sure to change any resistors in that set that are outside +/-20% nominal values.
I'll bet you'll find a few. With upward drift, any resistors in the mixer/osc stage that have changed may effect operation.
Check all coils for continuity of all sections, if have not already.
Chuck
91H Code 126 Restore
Philco 70 antenna lead
