philco470/490
Saw a post over on the other forum from some one who has a 470 that doesn't have a 70 or 90 chassis. It has a 51 chassis, did Philco produce a set like this??
Philco 470 - by Radioroslyn - 07-18-2016, 02:32 PM
RE: philco470/490 - by sam - 07-19-2016, 11:15 AM
RE: philco470/490 - by Radioroslyn - 07-19-2016, 02:35 PM
RE: philco470/490 - by sam - 07-19-2016, 03:11 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 03:24 PM
RE: philco470/490 - by sam - 07-19-2016, 03:39 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 08:12 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 08:20 PM
RE: philco470/490 - by Ron Ramirez - 07-19-2016, 08:32 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 08:51 PM
RE: philco470/490 - by Ron Ramirez - 07-19-2016, 09:45 PM
RE: philco470/490 - by mg34.42 - 07-27-2016, 10:57 PM
RE: philco470/490 - by Eliot Ness - 07-28-2016, 12:53 AM
RE: philco470/490 - by mg34.42 - 07-28-2016, 06:43 AM
RE: philco470/490 - by Ron Ramirez - 07-28-2016, 08:26 AM
RE: philco470/490 - by mg34.42 - 07-28-2016, 09:03 AM
RE: Philco 470 - by Ron Ramirez - 07-18-2016, 03:34 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 03:22 PM
RE: Philco 470 - by Ron Ramirez - 07-18-2016, 07:09 PM
RE: Philco 470 - by Radioroslyn - 07-18-2016, 07:20 PM
RE: Philco 470 - by Ron Ramirez - 07-18-2016, 07:31 PM
philco470/490 - by mg34.42 - 07-18-2016, 10:08 PM
RE: philco470/490 - by Radioroslyn - 07-19-2016, 06:39 AM
There are currently 9746 online users. [Complete List]
» 1 Member(s) | 9745 Guest(s)
