Philco 50 (early version)
Did you say nice or mice??
I had one not too long ago. PT was replaced, nowdays that's a pain cause the set uses 2.5v heaters.  I think it has louvers cut into the wooden bottom to help air circulation and makes a lovely entrance for the mice. As for the open output transformer it needs to be about 7K (plate load not dc resistance) on the primary. If you have a junk Philco transformer that was used on a set with a single (not married) 47,42, or 6F6 any of these will work well. All have the same load resistance.
Philco 50 (early version) - by klondike98 - 07-18-2016, 04:03 PM
RE: Philco 50 (early version) - by morzh - 07-18-2016, 04:08 PM
RE: Philco 50 (early version) - by klondike98 - 07-18-2016, 04:12 PM
RE: Philco 50 (early version) - by morzh - 07-18-2016, 04:26 PM
RE: Philco 50 (early version) - by Radioroslyn - 07-18-2016, 04:38 PM
RE: Philco 50 (early version) - by klondike98 - 07-18-2016, 08:39 PM
RE: Philco 50 (early version) - by klondike98 - 07-24-2016, 08:00 PM
RE: Philco 50 (early version) - by klondike98 - 07-24-2016, 09:51 PM
RE: Philco 50 (early version) - by KCMike - 07-24-2016, 10:17 PM
RE: Philco 50 (early version) - by morzh - 07-24-2016, 10:28 PM
RE: Philco 50 (early version) - by klondike98 - 07-28-2016, 11:29 AM
RE: Philco 50 (early version) - by KCMike - 07-28-2016, 11:51 AM
RE: Philco 50 (early version) - by klondike98 - 07-28-2016, 03:35 PM
RE: Philco 50 (early version) - by KCMike - 07-28-2016, 04:05 PM
RE: Philco 50 (early version) - by klondike98 - 07-30-2016, 07:44 PM
RE: Philco 50 (early version) - by sam - 07-31-2016, 01:00 PM
RE: Philco 50 (early version) - by klondike98 - 08-16-2016, 04:02 PM
RE: Philco 50 (early version) - by klondike98 - 08-16-2016, 04:52 PM
RE: Philco 50 (early version) - by Radioroslyn - 08-16-2016, 07:14 PM
RE: Philco 50 (early version) - by klondike98 - 08-16-2016, 10:10 PM
RE: Philco 50 (early version) - by sam - 08-16-2016, 11:04 PM
RE: Philco 50 (early version) - by klondike98 - 08-17-2016, 04:38 PM
RE: Philco 50 (early version) - by Radioroslyn - 08-17-2016, 09:50 PM
RE: Philco 50 (early version) - by Arran - 08-18-2016, 05:09 AM
RE: Philco 50 (early version) - by klondike98 - 08-24-2016, 05:58 PM
RE: Philco 50 (early version) - by klondike98 - 08-27-2016, 03:50 PM
RE: Philco 50 (early version) - by Radioroslyn - 08-27-2016, 05:50 PM
RE: Philco 50 (early version) - by klondike98 - 08-27-2016, 06:54 PM
RE: Philco 50 (early version) - by klondike98 - 08-28-2016, 09:52 AM
RE: Philco 50 (early version) - by KCMike - 08-28-2016, 10:43 AM
RE: Philco 50 (early version) - by klondike98 - 08-29-2016, 04:37 PM
RE: Philco 50 (early version) - by klondike98 - 12-19-2016, 09:08 AM
RE: Philco 50 (early version) - by Jason K - 07-29-2017, 11:39 PM
RE: Philco 50 (early version) - by klondike98 - 07-30-2017, 08:01 AM
RE: Philco 50 (early version) - by Jason K - 07-31-2017, 11:43 AM
RE: Philco 50 (early version) - by Mtmattking - 04-24-2024, 10:31 PM
RE: Philco 50 (early version) - by David - 04-25-2024, 12:46 PM
