philco470/490
(07-19-2016, 08:51 PM)mg34.42 Wrote:  ...it looks like what some one did was add the original cable to the 51
Based on your pictures, I am now inclined to agree.
Well, whoever made the conversion did a very good job with the cabinet; it's too bad they weren't so careful with the power transformer.
Philco 470 - by Radioroslyn - 07-18-2016, 02:32 PM
RE: philco470/490 - by sam - 07-19-2016, 11:15 AM
RE: philco470/490 - by Radioroslyn - 07-19-2016, 02:35 PM
RE: philco470/490 - by sam - 07-19-2016, 03:11 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 03:24 PM
RE: philco470/490 - by sam - 07-19-2016, 03:39 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 08:12 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 08:20 PM
RE: philco470/490 - by Ron Ramirez - 07-19-2016, 08:32 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 08:51 PM
RE: philco470/490 - by Ron Ramirez - 07-19-2016, 09:45 PM
RE: philco470/490 - by mg34.42 - 07-27-2016, 10:57 PM
RE: philco470/490 - by Eliot Ness - 07-28-2016, 12:53 AM
RE: philco470/490 - by mg34.42 - 07-28-2016, 06:43 AM
RE: philco470/490 - by Ron Ramirez - 07-28-2016, 08:26 AM
RE: philco470/490 - by mg34.42 - 07-28-2016, 09:03 AM
RE: Philco 470 - by Ron Ramirez - 07-18-2016, 03:34 PM
RE: philco470/490 - by mg34.42 - 07-19-2016, 03:22 PM
RE: Philco 470 - by Ron Ramirez - 07-18-2016, 07:09 PM
RE: Philco 470 - by Radioroslyn - 07-18-2016, 07:20 PM
RE: Philco 470 - by Ron Ramirez - 07-18-2016, 07:31 PM
philco470/490 - by mg34.42 - 07-18-2016, 10:08 PM
RE: philco470/490 - by Radioroslyn - 07-19-2016, 06:39 AM
There are currently 8931 online users. [Complete List]
» 2 Member(s) | 8929 Guest(s)
